Unable to load family files into Revit 2017.2
Message 1 of 27
I am not able to load family files into Revit 2017.2, even through the Insert - Load from Library - Load Family tab. We are working on a product that requires steelcase products so need to be able to load these into a project.
Replies (26)
Message 2 of 27
Sahay_R
Easy way - don't click on Architecture>>Component.
Instead - Insert>>Load Family.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 27
I do it this way as well and it still won't load.
Message 4 of 27
Are you on a Sheet or a View? Must be on a View to place family. See the + sign next to the family names? Click on it to expand the family types. Then drag a type onto your View.
Message 5 of 27
Yeah, I made sure I was in the view, then clicked the plus to the actual family and tried to drag it. For some reason not going into the model. It doesn't give an error or anything. Just doesn't do anything. But I know it's in there cause I see the family file
Message 6 of 27
Sahay_R
What category do those families belong to? By any chance do they belong to a category that has been turned off in VG?
Are you in the right phase?
Are you in a turned off Workset?
Look in the families - by any chances is there a visibility parameter that has been turned off?
Are there Filters set up in the view template?
Rina Sahay
Message 7 of 27
Kimtaurus
Have you tried opening the family and clicking "Load into Project" ?
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Message 8 of 27
Okay, I checked VG - They are a part of the curtain panel category and that, among everything else is checked to be visible.
I haven't even created worksets in this project, haven't gotten that far into it so that shouldn't be the issue. As well as there are no filters applied or a view template currently on the project.
Message 9 of 27
I did try this as well and didn't seem to work.
Message 10 of 27
Sahay_R
Share files. Share the destination project and one of the problem families. Without this we are only guessing.
Rina Sahay
Message 11 of 27
Here is the Project and a family file I am attempting to use.
Message 12 of 27
Sahay_R
Here's why - the family that you have sent me is a curtain panel.
Create and select a Curtain Wall>>Edit Type>>Curtain Panel.
When you click on Curtain Panel, you will get a drop down with all your families listed there. Select the one you want to insert.
Rina Sahay
Message 13 of 27
Would you be able to show how to get to this. How to create this?
Message 14 of 27
Message 15 of 27
Sahay_R
Here is what I would do - drop a curtain wall of the right size into the regular wall. ANY kind of curtain wall. The select the curtain wall, go into Edit Type. In Edit Type you will see Curtain Panel. Click on the drop down for that. All the Curtain Panel families that you have loaded into the project will show up there.
Rina Sahay
Message 16 of 27
So, If I do it like this it seems that there is no longer the ability to
edit the family itself like the the material properties of it and type of
glass used?
Message 17 of 27
Sahay_R
In the Project Browser - right click on the family name and click Edit. That will take you to the family, which you can then edit.
Rina Sahay
Message 18 of 27
Okay so, I'll have to edit the family itself in the project browser -- then it will be placed as a curtain wall system? You would think there would be a much simpler way to do this so they actually work as the wall system that they are supposed to.
Message 19 of 27
Sahay_R
One of the disadvantages of curtain wall doors, I'm afraid.
Rina Sahay
Message 20 of 27
Strange. So it's basically because of how the family was originally made? If I were to want to change materials on the same door lets same placing it in two locations, I would have to duplicate that family, change it's properties/materials and make a new "curtain wall?"
