Unable to install 2024.1
m_clough
m_clough
When i try to install the Revit 2024.1 update, i get this notification:
I've uninstalled Revit 2024 and performed a clean uninstall.  The path indicated in the image is the location of the installer resources (not sure what the precise term is) that contain RVT.msi and the 'setup.exe' is exactly the one i used to reinstall Revit 2024.
why doesn't it recognize the RVT.msi as valid?
DarrenP
Read this thread: https://forums.autodesk.com/t5/installation-licensing/problems-installing-revit-2024-update-1/td-p/1...
DarrenP
TB4
I run into the same problem and don't find the suggested link in the answer to solve my problem..
pieter.zeenaeme
Update Revit 2024.1.1 is unable to complete.
Stops at 92%.
Already tried the suggested answer without succes.
jay_colcombe
Post in the Installation and Licensing forum, i am seeing lots of 2024 installation issues and they will have dealt with most of the solutions
Installation & Licensing Forum - Autodesk Community
Jay Colcombe
Autodesk Certified Instructor
mvsolorzanog
Community Visitor
Community Visitor
Hi, could you solve that problem? My instalation stops at 97%
Simon_Weel
Wrong forum, but see this article.
