Transferring user defined property set names and values
kiddo_95
Message 1 of 18
kiddo_95
Hi Guys
I have a set of elements where I have assigned a group of property sets with specific names and to which I have assigned certain property set values. I want to transfer these property set names and values as they are to another corresponding element with a different geometry.
How can I do this without using dynamo?
Is there any plug-in for it or a direct way of doing it in Revit?
Any suggestion is welcomed.
Thanks in advance,
Cheers.
Replies (17)
Message 2 of 18
kiddo_95
Any hel here please: @hmunsell  @barthbradley
Message 3 of 18
What do you mean by "Property Sets"?
Message 4 of 18
hmunsell
it sounds like you made a bunch of project parameters and you want to transfer the parameters and there values to another Family/File?
Howard Munsell
Message 5 of 18
Parameters with Formulas?
Message 6 of 18
kiddo_95
I have this Revit family with a set of shared parameters that I have created before and have assigned some values.
I would like to transfer the shared parameters' names and values to a different Revit family/Multiple Revit families.
One can use the shared parameter file to transfer the shared parameters name. But how can I transfer the shared parameter values seamlessly?
I hope this helps. Looking forward to hearing from you.
Message 7 of 18
kiddo_95
No formulas (Just texts and numbers)
Message 8 of 18
kiddo_95
Correct. But I have created these parameters as shared parameters.
Message 9 of 18
hmunsell
try this....
Export Shared Parameters:
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-AD648C07-0C2F-478D-AD9D-4F9A5FF515E6
or
Transfer Project Standards:
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-5554B35B-7D43-4934-9245-35A29412F662
Howard Munsell
Message 10 of 18
anze.kumar
I use Add In "DiRoots for issues with shared parameters. However I didn't come accross an example like yours.
In the video below you could use it for assigning parameters, but to transfer the values, I think it is not possible with this Add in.
video:
https://youtu.be/1gQmrVrbJv0?t=909
Plugin:
https://diroots.com/revit-plugins/dirootsone/
Message 11 of 18
kiddo_95
Hi There
Using the shared parameter file only allows me to transfer the shared parameters' names but not the values. I have used it many times already.
The "transfer project standard" option doesn't work as well since I don't see an option there to transfer shared parameter names or values. One can transfer project information though, since it is a category.
Any other suggestions? Please!!!
Cheers
Message 12 of 18
kiddo_95
I tried to use it before and it didn't work as well. Took a second look again and I am not able to transfer the shared parameters' value.
Cheers,
Message 13 of 18
anze.kumar
What about SheetLink - it takes an effort with excel and modifying values and then importing it back to revit. It's still work with a third-party app, but at least it's not "coding" with dynamo 🙂
Message 14 of 18
kiddo_95
Apparently, you can perform some changes to the exported Excel file content and import the changes to the values of the shared parameter back to Revit.
However, I don't see a way of importing the exported Excell content back to a different element.
Is that right?
Cheers.
Message 15 of 18
You can turn the rfa into a template to start new families from. Change the extension from rfa to rft and then select the rft when creating a new family.  All the parameters/values/formulas in the original rfa will be there in the new rfa.
Message 16 of 18
kiddo_95
Well, that would work, but the problem here is that unfortunately, I don't have the .rfa of the elements, only their .ifc files. This means I would have to create for each of them a template first.
Much appreciated for the help.
Any further suggestions?
Cheers.
Message 17 of 18
hmunsell
well, i was rooting for @barthbradley solution of making a Template out of the RFA, but if you're using IFC's that adds another layer of complication to things.
i don't know of anything outside of maybe Dynamo that might be able to copy the values over.
  • Add the shared parameters manually or by 3rd party tool.
  • run a dynamo script to copy the values?
Howard Munsell
Message 18 of 18
kiddo_95
Thank you for your remarks and thoughts
