unable to insert title block into drawing
I have tried to insert a title block over and over but can't seem to do it.
I have followed the instructions to the tee. what am I doing wrong??
Alan.johnson1970
Could you provide a little bit more info?
What exactly are you doing?
You say inserting the title block into a drawing, are you in the title block editor, or a project?
How have you created the title block?
Is from AutoCAD?
Have you sketched it?
Can you attach file or images of what you have done / trying to do?
AJ.
cbcarch
1. Make sure you have a Revit Titleblock Family ( .rfa file) on your computer system/server.
2. In Revit; go to View> Sheet> then when prompted, specify the Titleblock family. It should load into your new Sheet.
Repeat as necessary to make new sheets.
That should do it.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
