Unable to insert decals
Hey everyone! I'm working on a project that I've inserted a few decals in already. All of sudden the other day, after creating 6 new decals, the "place decal" command stopped working. When I click it, instead of a drop-down menu appearing in the properties bar, it just remains as the view I'm in (in this case it's a 3D view).
The kicker is that it works perfectly fine in other projects, so something has gone wrong with this project...any ideas of what I can do? Thanks.
ennujozlagam
try tick audit before opening the file and see if helps. thanks
That didn't work
ennujozlagam
try to install latest updates from autodesk sometimes it helps. thanks
Thank you for your help. I'm not sure what updates I could use, as I've got a student licence for Revit 2020 and have been using it since July so it's relatively new.
It has begun working again!
