Hey everyone,
I've gone through all of the available forums and tried all of the solutions, but I still can't seem to delete the curtain wall or gridlines located underneath the stairs of this shop. Could someone please help me figure it out? I created the curtain walls on "T.O. Slab" level, but it is easier to see it all in the 3d model.
You can see from the pngs that there are also some curtain wall grids from a second curtain wall that need to be deleted. I've copied the curtain Panel >> Empty System Panel from a previous version's template because that is the solution other people suggested? But it didn't do what I wanted it to do.
To be clear: I want to delete (as in, completely remove everything that has to do with curtain walls) the wall objects so that I can start again with a different layout/arrangement of wall. Any solutions that don't remove all the objects/walls/panels/grids/mullions/whatever in the drawing is NOT what I'm looking for.
Thank you in advance.
