Unable to assign Scope Box to dependent elevation or dependent section views
loekvst
Message 1 of 9
loekvst
Available in version Revit 2022. No longer available in Revit 2023 and Revit 2024.
Assigning a scope box to dependent section and/or elevation views.
It would be nice to see this feature available again in an update
Replies (8)
Message 2 of 9
What about setting the Scope Box in the Parent before Duplicating as Dependent? Then remove Scope Box from Parent afterwards.
Message 3 of 9
EATREVITPOOPCAD
@barthbradley I tried this and it does not work 😕
The definition of insanity is doing the same thing over and over again and expecting different results
Message 4 of 9
syman2000
Weird. I am testing it out and the plan scopebox seems to work fine.
However when it comes to section, this is where scopebox is greyed out
It shows up fine with Revit 2022
Message 5 of 9
bihnerbr
Applying Scope Boxes to Dependent Elevations was such a great feature!  Yes, thankfully they still work on plans.  But using scope boxes on elevations really saved a lot time cropping views.
Message 6 of 9
marcin.ostrowskiQVECQ
Yes. Autodesk! Please fix this functionality.
Message 7 of 9
scott.viney
Can we get a rebate on tokens for core functionality removed?  Back dated to start of Revit 2023?
Message 8 of 9
neil_looney
Open a support case.
Message 9 of 9
vdaskalov
Revit 2024.3.4: Still not working.
