Message 1 of 10
Two wall joined - Common edge line weight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
We have prefabricated wall with 6 to 8 layers. We are modelling them as a Three Walls. With in each wall there are other layers also. At the moment this is the Course view.
When i joined the walls together it converts the common edge between two walls as a thin line. From where can i control the thickness of this common edge when wall are joined?
I checked every thing. Override in view, VG, object styles, filter. Nothing seems to be working.
If i change to medium and fine then i see the layer within each wall which i don't want to see. I just want to see the middle wall with thick lines and the side wall as thin line.
