03:57 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have a slab that is pinned and on a segregated workset with a user called "locker" that is currently owning that object ("Edited by Locker") - and never relinquishes those objects in that workset. It's not possible to normally edit the boundaries of that slab, not even for the user "locker" - because it's pinned. However, the slab boundary is being changed by any other user by moving a wall that aligns with that boundary.
So here goes a few questions:
- How is that possible that 2 users can edit simultaneously the same slab?
- Why no warning is displayed when a user changed an object owned by another user?
- Why a user that do not control another workset, can change objects in that workset?
- How is it possible that changing a wall changes a pinned slab? What sort of rules and priorities are in place that overrule the fact that the slab is pinned and owned by someone else?
- Are there other relations between objects in revit that override pin/owned objects?
- How can we effectly prevent that an object is changed? That building part is built, and we are already segretating into a separate workset. Do we have to place it on a linked file?
