Two Separate Building Pads Problem
cakir.omertr
Message 1 of 8
cakir.omertr
Hello everyone!
I have a building on a slope with a basement. I need to remove the soil that is getting inside the building. I used a building pad to remove the soil but because of the slope, I used 2 separate pads. But for some reason whenever the edges of the pads touch each other, it causes some graphical error or something like that on the section. Also, both of these pads are on different levels. One of them is on a higher level than the other.
Does anyone know how to fix this issue? (According to the images I uploaded, blue and yellow lines show my pads and the red line shows my section error.)
Replies (7)
Message 2 of 8
Post the file and we'll fix it.
Message 3 of 8
cakir.omertr
Here it is!
Message 4 of 8
Must have fell through the cracks. Nothing on my end.
Message 5 of 8
cakir.omertr
So do you have any suggestions for it or is this some other kinda problem?
Message 6 of 8
Deleting the tan subregion fixes it.
Message 7 of 8
All you have to do is edit and modify the sketch boundary of the tan subregion. Use the Offset Tool with "Copy" unchecked to inset the sketch boundary linework a bit.
Message 8 of 8
cakir.omertr
Thanks for the help!
