Two generic family's, need to cut with another one generic void family. is it possible ?
bimitaly
bimitaly
Two generic family's, need to cut with another one generic void family. is it possible ? like when we place a door in the wall, Wall will automatically cut as opening size in the door family. in the same way is it possible for generic family's ?
please give me your valuable feedback.
Thank you,
regards,
Satya.
@ToanDN @barthbradley @L.Maas @GustavoUbriaco
rxi.gg
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M...
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
GustavoUbriaco
Hello!
Generic model families can cut floors walls roofs and ceilings and some families I found this for you could be interesting Cut with voids when loaded
Thank you so much for the mention
Gustavo Ubriaco Contreras
bimitaly
Hi Roi,
1st thanks for your reply, but your solution not even close to my Question.
Satya
Yes.
A Wall-Hosted Family with Void(s)/Opening(s) cutting the Host Wall will cut the Host-Wall of another Wall-Hosted Family when Nested into it.
Does that answer your question?
