Twisted Reference Plane
npsteinr
npsteinr
How can I create a twisted reference plane? I only can do one that is sloped or flat. I am trying to create beams on a twisted roof. Thank you,
Nate.
Replies (12)
rendermaster
you cant....
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
You can get there by following the surface of a mass form
- Create a roof by face from the mass
- Create walls on plan where you want the beams and attach top to the roof
- Create beams by pick 3d lines and pick the intersections between walls and roof
Ha!
npsteinr
Thank you for the suggestion to mark pick 3d lines. I ended up making a grid (instead of walls) and making indiviudal beams. I was hoping to do this in the beam system comand. But this works well enough! Thank you very much for the response!
npsteinr
Did you do this using the method layed out by ToanDN ? Thanks,
Nate.
Nate.
No, I used the method that I said in post #3, and that @ToanDN repackaged in post #4.
loboarch
@barthbradley wrote:
Ha!
Actually i think you could get a roof like this with either a slope arrow, or shape editing, no mass needed.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
That is not even twisted.  It is just a flat plane and all the beams run parallel.  So a normal roof with either slope arrow, or vertical openings to cut the boundary, works.
Mine is twisted.  Beams are hosted to mass edges.  Nothing is plumb.  Reminds me of a fort I built when I was in first grade.
...do you guys know who Fritz Grupe is?
Nate.
No, I don't know what I am doing so I am just making some low and non-intelligent comment as usual.
Type a product name
