Twinmotion for Revit
joshua_s2V9T2
Observer Observer
joshua_s2V9T2
Observer
Observer
Hi, I'm hoping someone can shed some light on an issue I'm having with the Direct link tool for Twinmotion for Revit.
I have just updated my Revit to Revit 24.2 and Twinmotion to 2023.2.2 (the latest versions) and for some reason, my direct link is broken.
If I select open in Twinmotion from the Revit view tab, Twinmotion will open, but then not show the imported model.
Even after this, in Twinmotion if I go to Import --> Direct Link, it says “No Source Available”. Even after I had selected direct link in Revit.
How can I fix this?
handjonathan
Hi @joshua_s2V9T2
Thanks a lot for posting your question to the forums!   Im tagging @ryan.duell, who may be able to advise.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
ryan.duell
Hi all,
Revit and Twinmotion do have intended\supported versions, as follows:
  • Revit 2023.1 | Datasmith 5.0.3 | Twinmotion 2022.2.3
  • Revit 2024 | Datasmith built-in | Twinmotion 2023.1 or Twinmotion 2023.2
Revit 2024.2 is compatible with Twinmotion 2023.2
Now, there are some known limitations with direct link that we could be running up against here; please confirm the items from this page:
Known Issues for Twinmotion and Revit 2024 Interoperability
Ryan Duell
joshua_s2V9T2
Observer
Observer
Hi Ryan, thanks for that.
Somehow the issue resolved itself and I am now able to direct link with no issue... Must've been an issue with the file or something?
