Turn on/off annotation text in views / add on/off parameter to text note
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
On the Revit views I design in, I add notes for myself, or someone else to review. For example, it could say "verify they want dimmed light". That way I can follow up on that and delete the note once I got my answer and implemented a solution in Revit
But when I submit the interim plans (PDF) to someone else for review, I don't want to show those notes. So I want to add a global yes/no parameter or some other means to turn those notes on or off depending on who gets the PDF of the plan set. I think just preventing the notes to print to PDF would also be OK. Or just hide them whenever i switch the parameter to "no". it should be one parameter I change, and all my notes become visible, or invisible.
I played a bit with that, but couldn't find a good way. Annotation text doesn't have a visibility parameter that could be tied to a global parameter. I also couldn't think of some other type of text to use. Text are system families. I don't know if a loadable type of family could be used. I guess an annotation family could be used and manipulated. but that would taking notes more cumbersome.
Does anyone have a solution or an idea to build on?
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
