Turn off P&ID Modeler Pane
Message 1 of 12
How can I turn off the P&ID Modeler Pane that automatically opens every time I open a Revit model? Or just get rid of P&ID tool all together?
I just installed 2018 and blindly installed all the updates to stay current, including I guess the P&ID Modeler tool. I am an architect with no need for this function, and it stinks to have to close a window pane every time I open a model. I've tried to turn it off using Revit Options User Interface dialog and the View tab User Interface drop-down. No luck.
Replies (11)
Message 2 of 12
David_Knight
We uninstalled it and chose to ignore it in the Desktop App.
Message 3 of 12
I'm fine with that. Is there a way to uninstall certain updates independently, like the P&ID, or do I have to uninstall Revit 2018 completely and re-install?
Message 4 of 12
David_Knight
Use Add/Remove programs in windows like any other software.
Look for the addon by name.  In windows 10 just search for "P&ID" and you'll find it.
Message 5 of 12
IMCornish
I cannot find it in my list of Programs and keep getting this dialog when closing Revit:
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Message 6 of 12
Same problem here IMCornish. Have you found any fix for it?
Message 7 of 12
IMCornish
Sadly not, its a pain in the neck!
Andrew Robertson
Chartered Architect
Truro. UK
Message 8 of 12
Did anyone find a solution to this? It's a pain in the back side
Message 9 of 12
David_Knight
my best suggestions would be to reinstall it, then completely uninstall it again.
beyond that, no. sorry.
Message 10 of 12
IMCornish
How can you reinstall it then uninstall it if you cannot find it!
Andrew Robertson
Chartered Architect
Truro. UK
Message 11 of 12
David_Knight
i went to look for it, it's no longer listed in my Autodesk update app...
Perhaps they removed it?
Perhaps when we switched from being a Maintenance License to a Subscription license it was modified...?
I... I don't know what to tell you.
This article suggests it's part of "Collaboration for Revit"
http://blogs.autodesk.com/revit/2017/08/15/pid-modeler-revit/
**More Digging.
I dug it up here:
Log into your autodesk account.
https://manage.autodesk.com/cep/#products-services/updates
I went to Product Updates, and it's listed there.
Give that a shot maybe?
Message 12 of 12
IMCornish
I cannot believe that  I have found that it is "Not possible to uninstall P&ID modeler ...."  on the Autodesk Knowledge Network.  Why hasn't it been reported here?   See https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Pathetic, Autodesk!
Andrew Robertson
Chartered Architect
Truro. UK
