Hi!
I've modelled tunnel in Civil 3D (picture below).
There are different rock bolts all along the length of the tunnel (picture below).
The length of the bolts and their distance depend on quality of the rock and those paramaters change along the tunnel's length.
I have to model them too.
Do you have any idea how?
I plan to import model from Civil to Revit and then use Revit + Dynamo, but I'm not sure if it is the easiest way.
Thank you in advance.
Sanja ![]()
Would this not be easier in Civil 3D?
But if in Revit, you might create that by using a fence as the tunnel, with a segment of tunnel created as a rail and the rock bolts as balusters.
Or line based family with the rock anchors as an array within the family - spacing could be parameter controlled.
You will have issues down the line trying to get your tunnel to be underground.
How to do this in Civil 3D?
My aim is to model it as parametric as possible (there are 3 parameters here: length of the bolts, their distance along tunnel length and distance perpendicular to tunnel).
I would be happy if I could make at least one parameter (distance along tunnel length).
I expect some changes in the future when they start with excavating (in that case distance along tunnel would probably change).
Is it possible to model that in Civil 3D?
In worst case, I could model it non parametric, but I'm afraid of the future.
The image you posted is not that clear but yes you can. In brief as follows
What does first step mean?
If I understood well, I should:
1. Import tunnel from Civil 3D to Revit.
2. Make Dynamo for tunnel's alignment (including chainage).
3. Model bolts and array them along the path using Dynamo.
