TT61t00 font
TT61t00 font
Message 1 of 9
TT61t00 font
After printing revit sheets, I need to do some post-processing in illustrator. However, when illustrator opens the document, it says that there are fonts missing. (TT61t00 and TT63t00). Is there a font that I can install on my computer to avoid having to refind the fonts in illustrator every time I open a document?
Replies (8)
Message 2 of 9
Set the pdd printer to embed all fonts.
Message 3 of 9
I've had this issue with Illustrator. Sucks until you realize it can be easily corrected.
Message 4 of 9
Thank you! Does this box need to be unchecked?
Message 5 of 9
What? We're talking portable document format; not ai?
Message 6 of 9
Not that one. Click on edit button you will see the option.
Message 7 of 9
Adobe pdf is the printer that I'm using on Revit-- they then get opened in illustrator as pdfs!
Message 8 of 9
Ah, gotcha-- looks like the default is to never embed Arial, which is what my font was set as in Revit. Thanks!Capture.PNG
Message 9 of 9
Ah, gotcha-- looks like the default is to never embed Arial, which is what my font was set as in Revit. Thanks!Capture.PNG Thanks!Capture.PNG
