Trying to hide an entire category on certain sheets
I can hide elements but not the entire category. I know there is another way to do it, but I cannot figure it out. Any help is appreciated.
Corsten.Au
Hi
There might be a “View Template “ assigned to the view . Which is preventing you to make any changes ...
Hide the category in that particular “ View Template “
2. Other option is remove view template.
then it will become a default view. And you may make any changes .
hope that helps .
cheers.
Corsten
Building Designer
Hi. This sounds like it will work, so thank you! But how do I remove the view template?
Figured it out! Thank you!!
I have tried to remove the view template and then i hide the furniture workset in the sheet. But the furniture still appear on the sheet? May I know if I have a plan with furniture in a room, I need to create two sheet with one sheet showing furniture and the other without. What is the best way to create the sheets? Can I hide the furniture workset in the sheet or I would need to set up two plans views?
Thanks!
