Trying to create a pattern/bitmap onto an exterior perforated metal screen
chase.conn72
chase.conn72
I am student trying to create an external perforated steel screen on my building. I was trying to get a pattern or possibly a bit map design on it, but i have no idea how to go about this. If you are able to help it would be greatly appreciated:)
Revit materials can have a cut-out map applied - this can be any pattern that you can create.  The attached example shows a cutout for fencing material - where the dark parts become transparent when rendered.
chase.conn72
I am trying to make something where the pattern changes as it goes along the screen. Right now i do have the cutouts on the model but i am hoping to find someway where the perforations change to make a design of some sorts, kid of like a bit map.
Well you need to design that.  The cut-out pattern can be made to fit the whole screen - it doesn't have to tile.  So once you have your design somewhere then you can apply it as a map.
Try in a drafting view and apply black filled regions to create a pattern.  Export it as an image to create your map.  If it is a really big pattern, you might need to do it in parts and therefore create different materials for it.
chase.conn72
I see what your saying, i applied it to my project and was able to get a cutout map on the screen. Thank you for the help!
