trouble with revit installation
marineideocunha
Observer Observer
marineideocunha
Observer
Observer
Hello, I can't install the Autodesk Revit Trial, tried everything already, but this error keeps appearing. Please, help me.
rodrigo.bezerra
Have you administrator privileges? If you don't, you won't be able to install it. Also, check if you have installed all latest windows updates.
You may find more  help in some of THESE Knowledge Network articles.
Regards
Rodrigo Bezerra
marineideocunha
Observer
Observer
I do have administrator privileges, and windows is updated. I don´t know what else to do
@marineideocunha  Take a look at this:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Is your UAC still enabled by chance?  If so you might want to check that before modifying the registry.
RDAOU
Hello @marineideocunha
For Installation problems refer to the following link...All possible installation instructions were compiled in one post (the following link) on the Autodesk Installation and Licensing forum
http://forums.autodesk.com/t5/installation-licensing/recommended-steps-for-installing-most-autodesk-...
