08:00 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a user that is having problems selecting items that are chained together. Here is the scenario you select a wall then tab to select the chain of walls. Everything works great to this point. Then when you click to select the entire chain the original wall is the only item that gets selected.
We have tried several things to get this to clear up.
- Uninstall/Reinstall Revit 2013.
- Change his mouse.
- Unistall Revit and clean any and everything having to do with Revit 2013 from the system. Reinstall.
This install is a deployment that works great on every other machine in the office. Is there a setting, *.ini file setting, something, anything we can do to get this fuctionality restored.
BTW he has an old project that is still in Revit 2010 that this functionalilty still works in. Any help would be greatly appreciated.
Darek
