Trouble Opening My Revit File
Message 1 of 8
I have a Revit file (2014) that I used for rendering a townhouse project that will open but will buffer and stop responding once I click on something. Before I didn't have this problem. I'm using a PC with 32 GB installed RAM. The file is 63.7 MB. I suspect the file is just too large and has way too much loaded into it. I'm wondering if there is any possible hope of recovering it.
Replies (7)
Message 2 of 8
hmunsell
are you trying to upgrade the model to a newer version of Revit?
Howard Munsell
Message 3 of 8
RDAOU
@Anonymous
I do not have a 2014 version...but could open and work with it fine in Revit 2020 and 2022...below is a link for a 2020
version which you can download
https://we.tl/t-B5vBZtR2jD
Message 4 of 8
hmunsell
I would also recommend setting your Default View to a Floor plan or the Site plan instead of the Rendered view.
Howard Munsell
Message 5 of 8
No. I'm trying to open it so I can re-render after making a couple of changes. I made a separate file for the actual townhouse and linked it into this file (the site).
Message 6 of 8
RDAOU
You are still working in 2014!!! no plans to upgrade??
Message 7 of 8
Well this isn't for personal use. This is at my job in an architecture office.
