When I installed Revit 2021, I didn't select the additional components for 'Medium Image Advanced Material Library 2021'. So now I have revit with no material library installed.
How do I retrieve the Advanced Material Library 2021 without uninstalling and reinstalling revit again?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
You can download the contents from the link below
Thank you for this.
Why do all the AEC materials have a lock over them? How can I use them?
@Anonymous
Simply search for the material you need and add it/them to the document...then you can use/apply to elements in the project
The Lock means that the material library is protected from having materials modified, added, or deleted from its contents. If you create a standard material library for use by several members of a project team, you can lock the library to prevent unwanted changes.
See the following link for more info on how to lock and unlock libraries https://knowledge.autodesk.com/All About Locked Libraries
