Treads nosing and Riser
Hi guys!
I've created a stair by component with a monolithic run.
Now I'd like to have treads without nosing, but when I set nosing lenght to 0 Revit says "can't make stair".
The same thing happens when I set the riser thickness to 1.5 cm. Revit wants a minumum of 2 cm thickness
Do you know why?
Sahay_R
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Thank you rsahayUZMK9
this solution does not work. I have created a new monolithic run duplicating as you suggested.
nut I'm still getting the same massage. "can't make stair"
FGPerraudin
Can you send a file with only your stair so that we can have a look?
I think that your warning is more related to the overall geometry of your stair combined with these parameters...
François
Francois-Gabriel Perraudin
BIM management and coaching
Thank you all.
after the previous suggestion I have tried to duplicate both the monolithic run and the cast-in-place stair type.
This has actually worked.
Thank you guys
