Trapezoid panels
10 REPLIES 10
Message 1 of 11
Ilic.Andrej
874 Views, 10 Replies
Trapezoid panels
What is the best tool for modelling these trapezoid aluminum panels?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
10 REPLIES 10
Message 2 of 11
I'd use a Mass with infiled Adaptive Points component..with Repeat
Constantin Stroescu
Message 3 of 11
I show here , in brief, the workflow ...
Constantin Stroescu
Message 4 of 11
Thanks for this demonstration. It will definitely be useful for some future projects.
The form that I'm looking for is flat, like in the picture bellow. The panel grid lines do not run in parallel to each other. So, I can't use Divide Surface... That's the problem.
Andrej Ilić
MSc Arch
Message 5 of 11
Then like this?
if so , then the same procedure as the first but only with U Grid Lines and instead of V . use Add Edge to an extruded (vertical extrusion from Level 0) and modified Mass
Constantin Stroescu
Message 6 of 11
How did you set the surface interior vertical lines to follow the shape of the plane? What I keep getting is this...
Andrej Ilić
MSc Arch
Message 7 of 11
martijn_pater
in reply to: Ilic.Andrej
Message 8 of 11
martijn_pater
You could use Parts, btw is it a vertical surface?
Parts panelsParts panels
Message 9 of 11
Ilic.Andrej
in reply to: martijn_pater
@martijn_pater Yes. I'm thinking of using parts but I'm really curious about this <devide surface> method so I'm awaiting for a response from @constantin.stroescu .
Andrej Ilić
MSc Arch
Message 10 of 11
something like this:
Constantin Stroescu
Message 11 of 11
Thanks, that's what I was looking for.
Andrej Ilić
MSc Arch
