Transparency on 2019 materials
3 REPLIES 3
293 Views, 3 Replies
Hello there,
I'm working on Revit 2019.2. Recently, I ugraded my material library to include new 2019 materials.
However I'm facing an issue I could not solve by myself.
When i'm setting a transparency on a wall with 2019 material, it  does not work in realistic visual style (shaded visual style works fine):
Neither element replacement nor filter replacement works.
I would like to still use 2019 material in project, instead of going back to the old.
Does anyone have an idea of what I can do to solve this ?
Cordially
Tags (2)
3 REPLIES 3
Materials changed in 2019. One of your Materials is using a Legacy Asset and the other is not.
See "Advanced Materials" section here:
http://www.aecbytes.com/tipsandtricks/2018/issue83-revit.html
martijn_pater
Check your material assets.
in reply to: barthbradley
Yes, I know that they are not using the same asset, and I would like to use the new asset. But if I use it, I can't change an element transparency in a single view (like if I want to set on some transparency on a wall in a 3D presentation view to see the equipment behind).
It is something that is locked with the new asset ?
