Transferring View Templates
aangle
aangle
Early this week Revit 2014 View Templatse were transfering from one project to another as expecting and working well.
Today I can get the View Templates to transfer from one project to the next.  Its even the same Template that was working ealier this week.
Any thoughts or know issues?
Allen
HermanSolomon
Can you give us more information on the steps you took to transfer template properties and parameters from the 2014 template to the other project? Typically one starts a project based on a template, but I understand that some projects might have already been started before a template was created.
http://revitrecess.blogspot.com/
Do your View Templates consist of any Filters?
aangle
As I did early this week I opened up 'model a' and and unchecked all, all I wanted to trasfer was 'View Templates' from 'model a' to 'model b'.  All work as expected, the 'View Templates' were added to 'model b'.  Yesterday I tried to tranfer the 'View Templates' from 'model b' to 'model c', did not work, then I tried 'model a' that I had used before and it did not work either.  All three were existing Revit models, and 'model a' had the templaces in it becasue they had been transfered from antohter existing model at a different time, 'model X'.  I even tried tranfering the templaces from 'model X' into 'model b with no luck.
I did notice later when tyring to do that that the Tranfer process and green bar in the lower left corner move slow and steady but when it hits 27%, boom its done, finished.
I later tired tranfering the 'Browser Organization' since I didn't get that to come in with 'View Template' and that did tranfer in.  But still no luck with the 'View Templates'.
aangle
Yes, disipline and other View Type Filers are in their, I have change to 'all' to look for the ones that were to be tranfered in, but they are not there.  Either way they tansferd from one model to another at one point, see ohter feed comment on that.
That is not what I mean.  I mean the Filters below.
aangle
Thanks for the clairfication, no their are not Filters there.
