Transferring Legend Views
a.sundaram
Message 1 of 12
a.sundaram
Is there any way to transfer the legends from one project to another like Drafting views? or any add-ins or Scripts to help with?
Alagappan
@Anonymous @bushra_aboelezz @prabhu.rMQVQ9 @shravan.krish @Anonymous
Replies (11)
Message 2 of 12
mmclean4U7JV
Yes this can be done.
If you have both Revit projects open (same version and same revit instance (not 2 applications of revit running, but 1) then on a sheet view you can just copy a legend you want (CTRL C) and paste (CTRL V) across to the other project (on a sheet view)  I have done this numerous times with always success.
This will paste the legend view and the legend will auto create in the 2nd project.
Hope this helps.
Message 3 of 12
benschilders
You could try to use pyrevit, there is a pyrevit script (clickable tool) wich let you select wich legends to copy to wich open projects (same sesion )
1. click on Copy Legends to other documents
2. select project wich to copy to
3. select legends to copy:
Download:
https://github.com/eirannejad/pyRevit/releases
Pyrevit basics:
https://revitpure.com/blog/10-amazing-pyrevit-features-to-save-insane-amounts-of-time
BTW pyrevit contains a lot of usefull tools !
Oh just a small reminder the idea forum is not the best place for questions, those should be asked on the regular formums:
https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133.
Hope this helps!
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Message 4 of 12
Alagappan
Aside from pyRevit, if you use Revit 2022 or 2023, you can select a legend on a sheet in project A, CTRL+C, and paste on a sheet in project B.
Message 5 of 12
benschilders
This is also a really good option , actually might be the most easy way when just wanting to copy one or two legends.
Just tested it in Revit 2020, it works as well, so i guess this works in 2020, 2021, 2022 and 2023.
Message 6 of 12
You can place a bunch of legend views on a sheet, select all of them and copy paste.
Message 7 of 12
shravan.krish
@a.sundaram I think this will be a really quick and simple solution . Maybe not everytime.
You can do this for now in my opinion.
Message 8 of 12
benschilders
@ToanDN  Fully agree with you ! Know i think of it i always use this technique when wanting to add multiple schedules from our template to older projects wich miss those, so i guess it is just preference or you use the sheet copy technique or pyrevit.    Therefore i should't have said " just wanting to copy one or two legends."
Offtopic:
Really love the  fact that all the parameters used in the schedule's automaticly get coppied into the project as well.
Message 9 of 12
silasT2BTM
Is pyRevit for Revit 2025 also?
Message 10 of 12
David_W_Koch
@silasT2BTM
They are working on it.  Volunteers work on this open-source project when they have time.  There were a lot of changes with the 2025 release that affected pyRevit, so there is a lot of work to do to support Revit 2025.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 11 of 12
ehoL7F5X
Community Visitor
Community Visitor
I have Revit 2025 and the Legend is in Revit 2022. I tried copying multiple times but it did not work. Bummer.
Message 12 of 12
autodesk_user1_ntec
Community Visitor
Community Visitor
It's helpful. Thanks.
