Transferring Legend Views
a.sundaram
a.sundaram
Is there any way to transfer the legends from one project to another like Drafting views? or any add-ins or Scripts to help with?
Alagappan
@Anonymous @bushra_aboelezz @prabhu.rMQVQ9 @shravan.krish @Anonymous
Replies (10)
mmclean4U7JV
Yes this can be done.
If you have both Revit projects open (same version and same revit instance (not 2 applications of revit running, but 1) then on a sheet view you can just copy a legend you want (CTRL C) and paste (CTRL V) across to the other project (on a sheet view)  I have done this numerous times with always success.
This will paste the legend view and the legend will auto create in the 2nd project.
Hope this helps.
benschilders
You could try to use pyrevit, there is a pyrevit script (clickable tool) wich let you select wich legends to copy to wich open projects (same sesion )
1. click on Copy Legends to other documents
2. select project wich to copy to
3. select legends to copy:
Download:
https://github.com/eirannejad/pyRevit/releases
Pyrevit basics:
https://revitpure.com/blog/10-amazing-pyrevit-features-to-save-insane-amounts-of-time
BTW pyrevit contains a lot of usefull tools !
Oh just a small reminder the idea forum is not the best place for questions, those should be asked on the regular formums:
https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133.
Hope this helps!
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Alagappan
Aside from pyRevit, if you use Revit 2022 or 2023, you can select a legend on a sheet in project A, CTRL+C, and paste on a sheet in project B.
benschilders
This is also a really good option , actually might be the most easy way when just wanting to copy one or two legends.
Just tested it in Revit 2020, it works as well, so i guess this works in 2020, 2021, 2022 and 2023.
You can place a bunch of legend views on a sheet, select all of them and copy paste.
shravan.krish
@a.sundaram I think this will be a really quick and simple solution . Maybe not everytime.
You can do this for now in my opinion.
benschilders
@ToanDN  Fully agree with you ! Know i think of it i always use this technique when wanting to add multiple schedules from our template to older projects wich miss those, so i guess it is just preference or you use the sheet copy technique or pyrevit.    Therefore i should't have said " just wanting to copy one or two legends."
Offtopic:
Really love the  fact that all the parameters used in the schedule's automaticly get coppied into the project as well.
silasT2BTM
Is pyRevit for Revit 2025 also?
David_W_Koch
@silasT2BTM
They are working on it.  Volunteers work on this open-source project when they have time.  There were a lot of changes with the 2025 release that affected pyRevit, so there is a lot of work to do to support Revit 2025.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
ehoL7F5X
New Member
New Member
I have Revit 2025 and the Legend is in Revit 2022. I tried copying multiple times but it did not work. Bummer.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
