Total File Language Conversion
Message 1 of 12
23379520_1754115617933328_409369714_o.pngHi,
I'm most likely not the first to ask this. Is there a way to do a complete translation of the text in basically all files that may contain another language? Everything here in this file is Spanish and I would prefer English to be wired into all of the text.
Replies (11)
Message 2 of 12
ennujozlagam
@Anonymous hello, go to your desktop > right click the revit icon > properties > change the language. please see attached.
then go to options > file locations and change your default template.
Message 3 of 12
Sorry, I must've explained it wrong.
The file that I'm currently using in REVIT 2017 is in Spanish. I want to convert that file from Spanish>English.
My default language is set to EN (US). However, the downloaded file as opened, has values and text set to Española instead of English.
Message 4 of 12
ennujozlagam
@Anonymous hello, you can refer to these LINK . thanks
Try the following. Exit Revit session and edit Revit.ini (Back up first your Revit.ini just incase) file in Revit Program directory. Find lines that look like
[Language]
Select= ESP
Change to ENU
Message 5 of 12
This link is void of my enquiry or I must be unrefined in knowing the process of this.
Message 6 of 12
ennujozlagam
@Anonymous  hello, i can access the link. change your internet browser. thanks
Message 7 of 12
I have accessed the link.
The contents inside the link have no correlation with my question.
It has not answered my question or given me tips how to approach it.
Message 8 of 12
ennujozlagam
@Anonymous hello, can share the file, i will try to open in my Revit version. thanks
Message 9 of 12
ennujozlagam
@Anonymous  Hello, I don't think this is possible to change into the English language because some text is manually keyed and its from original spanish template. i cannot help much. thanks
Message 10 of 12
I see.
This should be recommended to Revit suggestions then.
I've seen Google Chrome translate a Facebook comment section from a language to another.
This can be possible through a system implementation for the coders of Revit.
Message 11 of 12
ennujozlagam
@Anonymous Hello, you still can wait until someone from Autodesk developer/specialist reply to this issue and what they will say or can post on Revit idea-not sure? Thanks
Message 12 of 12
Alfredo_Medina
I don't think there is a way of automatically translate all the terms in the file from Spanish into English (names of views, names of titles, names of parameters, names of families, etc.). Most likely the only way is to hire someone to do that.
