Toposolids by csv are offset on global coordinates
- Mute
- Permalink
- Report
Using Revit 2025 I have been trying to create a toposolid from points in a csv file that have been digitised on OSGB36 (British national grid) I am using a revit file pre set-up to place the toposolid close to the internal origin but am getting a result that offsets the position of the toposolid from the coordinates that have been digitised.
I have attached the .csv file.
Below shows the digitised coordinates
And here in Revit the coordinates on the left reflect the highlighted coordinate above. So there appears to be an offset of roughly 19m West and 6m South from the cooridnates in the .csv file
I have also found that toposolid creation this way doesn't honour share coordinate rotation which is a bit of a disappointment.
In short it looks like toposolids don't play well with shared (global) coordinate systems which working in measured survey is a disappointment, because in many other ways they support topographic survey much better than their predecessor toposurfaces.
I can do a manual fix by offsetting, but this doesn't bode well for the wider use of toposolids for existing conditions.
