Toposolid from Cad creates a void in the wrong place
2 REPLIES 2
smartplans
165 Views, 2 Replies
I have created a DXF topography file using QGIS  which when imported and converted to a Toposolid  creates a void area that should not be there. This did not happen when creating a topo surface from cad import.
The graphic below shows the DXF in its imported form on the left and the converted solid on the right. The hole on the left has been created by Toposolid and interferes with the building placement. Can anyone assist?
2 REPLIES 2
edit toposolid boundary (double click) and remove the hole
ridantuo
in reply to: smartplans
I've fixed these so far by making a dummy boundary (rectangle) around the topo lines in the DWG/DXF and giving them an estimated elevation.
EDIT: Luckily I haven't had to work on or close to those boundaries yet.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
