toposolid edit- contours disappear
ar00302
ar00302
Hello.
I create a toposolid by sketch and then i cut a part of it using a model in place void.
The problem is that i am not able to see contours after that.
Why?
thanks
handjonathan
Hi @ar00302
Thanks a lot for posting your question to the forums!   Im tagging @Alfredo_Medina @ToanDN @SteveKStafford who may have some suggestions on how to help.
Jonathan Hand
Technical Marketing Manager | Construction
ldefazio
Community Visitor
Community Visitor
Hi I am creating a new toposolid in Revit 2025.3 and cannot get the contour lines to appear. I have imported a toposurface from a previous file and the contours appear on there. I have  set the toposolid parameters - contours / structure etc; and still no contour lines appear..
Thank you..
