Toposolid Cut Pattern
kmatis
kmatis
Since the support case site seems to be down I am trying to post here. I am starting to use the new toposolid feature but the cut pattern doesn't show up in all section views. It will show in one and then I rotate the section 90 degrees and it no longer shows so I know it's not a view setting. Is this a limitation to this new feature?
Is it Cut?  Does the Material have a Cut Pattern?
...what you you mean ""rotate the section 90 degrees"?
....Rotate on Sheet?
Your issue sounds Graphics related. Try disabling hardware acceleration.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Changing-the-Hardw...
Check phasing of the view.  Is this Show Complete?
kmatis
It looks like it had something to do with the mass void I created for the building cut out. I recreated it and now the toposolid displays correctly.
