Topography Rotated incorrect with option from file
Message 1 of 21
I have a model that is orientated 'by shared coordinates'in RD-new for the Netherlands
When i import a file that has the ground contours to make a mesh the angle is incorrect.
Even when i use true north. Please supply the correct steps to import this in a correct way.
Replies (20)
Message 21 of 21
dennis.huisman
The question is about the link topo funktion available since revit 2019.1.
Using this you should be able to update the topo and there is no need to reproduce the surfaces when the civil engineer updates the civil model.
