topo survery from dwg
pushenergy
Message 1 of 14
pushenergy
can someone tell me quickly which layer i need to bring in from the attached CAD file to create a contour map? i gte mixed results i thought it would be the contour layers?
Replies (13)
Message 2 of 14
Sahay_R
Major and Minor Contours.
What mixed results are you talking about
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 14
@pushenergy
Can you save the DWG to 2013 version?  I can't open 2018 files.
Message 4 of 14
I'm a little confused. The dwg is planar. There is no definition.
Message 5 of 14
Sahay_R
You can save AutoCAD DWGs back to an older version.
Can you share a RVT with the incorrect toposurface on it?
Rina Sahay
Message 6 of 14
What, @Sahay_R? I opened the DWG just fine. It's a 2D drawing. There is nothing to articulate a contoured surface in it.
Message 7 of 14
Sahay_R
Yes it is a 2D DWG. That's what the OP is going to use as a basis to drop his points on to generate elevations. And I was not the one who had trouble opening the file.....
Rina Sahay
Message 8 of 14
sorry. guess that sounded challenging. My bad. Smiley Embarassed
Message 9 of 14
ennujozlagam
@pushenergy   hello, layer of contour point is SS_LEVEL_PNT.  there should be a value of your Position Z once you link your cad into revit to create a toposurf., unless you key-in your elevation point manually. thanks
Message 10 of 14
LMAO!!! That's exactly the point I have been making: There is no "Z" in the dwg.  This begs the question: WHAT IS THE QUESTION?  "Can someone tell me quickly which layer I need to bring in from the attached CAD file to create a contour map?" What does this mean?
...okay, sorry. Just having a rotten day. Love you all.
Message 11 of 14
pushenergy
Yes there are Z points i have now found them on a layer called 3D points,
Message 12 of 14
ennujozlagam
@pushenergy hello, you are right the layer is SS_3d it was freeze that why we don't see them. thanks
Message 13 of 14
Viveka_CD
Hi there @pushenergy
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Message 14 of 14
yes sorted now thanks i cant see answered  option....
