Message 1 of 14
Topo surfaces and building pads with "holes"
11:07 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi:
I am working in a building in a very steeply site, so I want to show each plan in an isometric view. I have a section box in the isometric views. I have a topo surface and a number of buildings pads that work fine in plan and section.
In isometric views, however, the area below the pads is empty, as if the pad would make a hole. I'm attaching two drawings, one of the whole surface and other with the section box in a lower level showing the problem.
Is there a workaround? I have read about using masses instead the topo surface but it sounds really complicated.
Thank you very much
