Top Railing fillet issue
rodrigo.bezerraRD5KM
I can't figure what's wrong in my top railing settings. The start extension (yellow highlight) is fine as desired, but the ending one (red highlight) is breaking.
Attached is a stripped version of the model.
Replies (8)
That radius won't work. Edit Rail Join and change it to a miter.
...you can try smaller radii too.
That's odd, because the radius works at the start without editing the rail. And I'm not supposed to change a design I do not conceived. The designer wants it to be a fillet join.
I appreciate the remark and will investigate if I can accomplish the same result with different radius. I can change that.
The radius is too large for the short segment at the corner.  See revised file.
But why Revit draws a segment that's different from what I set in the top rail type?
The top rail has been manually edited.  If you Tab select the top rail and Reset you will see the original form.
For railing @ odd configurations, I prefer to use a top/handrail type without extension, and edit them and add the extension manually to get exactly what I need.
Your Rail as a custom configurations. Basically, rules to follow. Why not set all segments to BY HOST and TYPE, and create a "dummy" stair to host the Railing - then hide the "dummy" in the Views?
The problem is with your Top Rail PROFILE Family (CDC_PerfilCircular_GuardaCorpo.rfa).  Origin Ref. Planes need to intersect at the center of the circle like this:
... Just select Railing in Project and press Reset Railing. Then load revised Profile into Project.
If you use the revised profile then you need to change the railing Height in the type properties to account for the added dimension (1/2 the diameter of the top rail).
By the way, I don't know what part of the world you are from, but where I am, you cannot have the horizontal extension immediately at the bottom step, you would need to extend the slope further, then a horizontal extension if required.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
