Too many missing elements
badstibnerm
Message 1 of 10
badstibnerm
File cannot be opened because there are too many missing elements. Told to contact Autodesk Support but I get no number. Please help.
Replies (9)
Message 2 of 10
You can contact Autodesk support through https://knowledge.autodesk.com/contact-support
...you might try opening file with "Audit" checked.
Message 3 of 10
cbcarch
Take a look here:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 4 of 10
While waiting for the Support to response and solve it, if they ever will, try:
- to open the model with Audit
- open a backup
Message 5 of 10
badstibnerm
Thanks for the responses.  We've tried every combination of opening:
--Local vs. Central
--Audit checked vs. unchecked
--Detach from Central checked vs. unchecked
--Preserve Worksets vs. do not preserve
--Specifying worksets to Open
Worked this morning.  Restored to that version and to the previous version (day before).
None of these have worked.  Still get the error.
Only one person working on this now so there is no available local file from a different user to try.
We're stumped.
Message 6 of 10
brettgatti
When trying to restore to an earlier backup, are you deleting your local and network Revit "backup folders" prior to opening and also opening with Detach From Central?
Message 7 of 10
badstibnerm
Thanks.  Good idea, but it didn't work.  Same error.
Message 8 of 10
cbcarch
Try signing in and out of the Adesk account, on all PCs.--
sometimes a user name gets "lost".
Cliff B. Collins
Message 9 of 10
anriae
Hi there, I'd just like to know if you resolved the issue? You've been very thorough with your checks and we've done the same but also have the same error occurring.
Message 10 of 10
badstibnerm
Good & bad news - Bad news is that nothing we tried worked.  We could not recover the file ourselves, and we really don't know what happened.
The good news is that we went through our reseller who sent the file to Autodesk.  They were able to recover in just a few hours.
