- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
For an existing building project i need to re-create the actual toilet stalls. Typically I use the "specialty equipment" stall families. but i have some existing ADA stalls that are larger than typical and have the door on the side (they are at the end of the room). that would require me to change that family quite a bit and got me thinking why don't i just use walls and doors to make stalls?
Is there some reason we use the specialty families? They seem convenient since they contain the grab bar and possibly toilet paper roll and sometimes the WC. The advantage seems to be one can place many complete stalls quickly.
But that also makes it inflexible (think scheduling the bar, WC etc. separately). For new construction it would be less of an issue since I can just make "normal" stalls.
any advice on using actual walls/doors vs the specialty families?
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
