Toggle in perspective view
Message 1 of 8
Are Revit working on the feature to toggle and walk inside the model i Perpective view in upcoming updater of Autodesk Revit?
They have this feature in ArchiCad and it is really outsatnding and highly recommended.
Replies (7)
Message 2 of 8
L.Maas
In general Autodesk never mentions where they are working on. You could check if there is already an entry in the Revit Ideas section or post a new one
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
constantin.stroescu
I am not sure I understood you well ,but a toggle between a 3d View and a Perspective View can be done
Constantin Stroescu
Message 4 of 8
Toggle IN perspective view
Fredrik Pettersson
Gruppeleder Arkitekt Trondheim
Arkitekt MSA
tegn_3
D +47 926 71 800
T +47 08 346
www.tegn3.no
Message 5 of 8
semko_dm
Hi!
As far as i know Autodesk working in this direction, but not inside Revit.
They released a new program called "Autodesk LIVE". Maybe this is what you're looking for.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Message 6 of 8
This is more for presentation. Good though. Im looking for a solution for the design process and modelling in Revit. The possibility to model and view, move, walk in perspective view.
Fredrik Pettersson
Arkitekt MSA
tegn_3
D +47 926 71 800
T +47 08 346
www.tegn3.no
Message 7 of 8
loboarch
In 2017.1 you can edit/author in a perspective view. All commands are enabled.
The ability to "walk" in a perspective view has been around for quite some time using the steering wheel navigation tool. See Nav wheel in lower left.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 8 of 8
Ok. But you cant toggle, and easily walk inside the model in perspective mode? As in ArchiCad for example?
You have to make a new "photo", perspective point, work, and then make a new "photo", perspective point, NOT Toggle?
Fredrik Pettersson
Arkitekt MSA
tegn_3
D +47 926 71 800
T +47 08 346
www.tegn3.no
