to Solve the Node with parts and original- intersection specific wall
Sorry guys to interrupt you. I did have to fix this node of frame wood wall where those 3 wall intersect. Actually with the parts I could find a better way to control single surfaces of wall sheet , the fact is that you cannot control the shape handle in slanted way and some void remains unfilled. The image will get you an answer. The original node is always a selction of these different options. Ec Extend single segment to the final edge, extend to corner to other wall, wall joins, join geometry and edit profile.. no one for many different problems get a clean interesction walls of the node. any answer? i get you the project with the detail ( dwg node) and the rvt file.
Use System Walls -- not Model In-Place Walls.
