Additional copies of the file in the family folder automatically created
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
mhotwani
636 Aufrufe, 7 Antworten
Hi I have created custom sheets but in the title blocks I have 3 of the same sheet including BAK file. Why has that happened. Is there something I need to switch off in the programme?.
7 ANTWORTEN 7
Nachricht 2 von 8
martijn_pater
als Antwort auf: mhotwani
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2019/...
edit: hmm your title and question are confusing. thought you were looking for above. now not so sure
Nachricht 3 von 8
als Antwort auf: martijn_pater
I read it the same way as you -- however the BAK (an AutoCAD Backup) is unrelated to Revit.
Nachricht 4 von 8
mhotwani
Thanks Martiyn  with your previous email
In fact it seems to be generating multiples of files with DrawingA.0002,  DrawingA.0003 etc not sure how to stop that.
Nachricht 5 von 8
martijn_pater
Perhaps you can share the file (as .zip) and/or screenshots of the issue.
Nachricht 6 von 8
mhotwani
Hi Martijn
Attached image in my document folder.
It creates series .0001 files. There are sometimes 8 or files which I delete.
Nachricht 7 von 8
martijn_pater
See my first reply and follow link I posted there, set the maximum backups to a lower number (minimum 1) while saving the file to reduce the backup interval if you like.
Nachricht 8 von 8
mhotwani
