to export DWG without external images references
TomasoCardia
TomasoCardia
Hi All!
I have some problems to export from revit to dwg a plot with a images (the signature of project). I don't want that this image is as a external reference but inside the file (as a OLE object for example); because I need to send the plots as a one file (neither compressed as zip or similar).
Thank you !
andybrack
As far as I know, what you want to do is not possible.  Revit will always export the raster image as a separate file.  This image file is referenced in to the resultant .DWG file.  You can address the problem in AutoCAD by following the instructions in the link below.  This isn't too bad if you have a hadful of drawings. However, this will be very time consuming if you have a large number of files.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Saving...
