Door family
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
Yara-architecture
547 Aufrufe, 11 Antworten
Door family
I create a door family with thickness wall 150 c.m  but i can't insert it in the project with a deferent thickness of the wall
11 ANTWORTEN 11
Nachricht 2 von 12
Sahay_R
als Antwort auf: Yara-architecture
Was it created in the Door family template? Door families will adjust to the thickness of the walls.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 12
Yara-architecture
als Antwort auf: Sahay_R
yes, created in the Door family template
Nachricht 4 von 12
if i insert it in wall with thickness for example 300cm it doesn't insert
Nachricht 5 von 12
Sahay_R
Remove the wall thickness from the door family. The only dimensions that you should control will be the door dimensions, not the wall.
Rina Sahay
Nachricht 6 von 12
it doesn't cut through the wall? Or, it doesn't recognize the host as a wall?
Nachricht 7 von 12
Yara-architecture
als Antwort auf: barthbradley
yes, it doesn't cut through the wall
Nachricht 8 von 12
Sounds like the door family uses a void cut instead of an opening cut. It probably isn't constrained correctly. Verify this it aligned and locked to the wall edges in the family -- or replace it with an opening cut.
Do you want to post family?
Nachricht 9 von 12
Yara-architecture
thanks  for the help.
Nachricht 10 von 12
Yara-architecture
no, i don't want to post it, i will try that locked it to the wall edges in the family. thanks  for the help.
Nachricht 11 von 12
okie dokie. Just to be clear: when I said "void cut", I meant that a void extrusion might have been used in place of the typical opening cut. So I was thinking that the extrusion isn't deep enough to fully cut through the wall. If so, easily fixed as I described.
Good luck
Nachricht 12 von 12
Yara-architecture
thanks a lot.
