Tittle sheet parameter default prefix
yes_and_no
yes_and_no
Guys, the title sheet parameter "project issue date" has prefix" as " "issued". How do we change it to "printed" ?
Sounds like the Prefix is part of the Label. Edit the Label in the Titleblock Family and remove Prefix from it.  If that ain't it, then post a screenshot of what you are referring to.
...or, are you referring to this:
Edit the title block family, edit Project Issued Date label, change prefix in label from Issued to Printed.
You really want the Titleblock's "Project Issue Date" to read "Printed"?
Interesting.  Maybe something like this would be better:
...or maybe add and use "Sheet Issue Date" Label for print date?  That way you can manage it through a Sheet List as well.
