TitleBlock with typemark label
postULB
postULB
Community Visitor
Community Visitor
We want to create a titleblock for door og window-drawings, where the titleblock displays the typemark of the door or window that i placed on the sheet (only one door or window per sheet).
I have tried adding a label (Assembly: Type Mark), but this doesnt work.
Thankfull for anny replys.
RDAOU
@postULB
Do the following:
  1. Create an Assembly of each door type >>
  2. Give the Assembly the same Type Mark of the Door (and/or Same Type name)
  3. Create views + check the box for sheet and select the title block you added the lable to
  4. => a sheet for that assembly will be created with the parameter Assembly Name and/or Assemble Type Mark filled
  5. Select the created views and place on that sheet
PS:
  • that sheet will be listed under the assembly (collapse and scroll down)
  • Updating the tpe mark of the Door itself will not update the type mark of the assembly. ie: you need to either update that manually or use dynamo
postULB
Community Visitor
Community Visitor
Thanks, i will try this.
