Titleblock transparant logo on background color
Xapod
Xapod
I run into the following issue when creating my titleblock family.
The titleblock contains a big rectangle and inside of this rectangle is the company logo.
I would like to be able to set a color background for this rectangle with the logo visible on top. However when I place the logo (image as .tif format with transparent background) the image messes up the background color.
See screenshot to better understand the problem
Is there a way to fix this?
Convert the TIFF to PDF and place it.
Xapod
Thank you for your quick reply. However i tried it and I still get the same result?
kostask_oionei
Have you tried with transparent .png?
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Share the TIFF file here, assume it already has an alpha channel.
Simon_Weel
Save yourself a lot of hassle - enlarge the logo canvas to cover the rectangle in the title block. Revit doesn't do transparency in images.
