TITLE BLOCK SHEET PRINTING MARGINs !!!
maramuresul
maramuresul
How to print an A3 Sheet using Microsoft Print to PDF or other printer, without printing ouside 5mm margins.
Please find attached.
Kind regards,
Andrei Ciorei
Revit_Whisperer
You will need to either fix the view crop or change the scale of the view so it fits on the sheet
Revit_Whisperer
If the viewport extends past it will try to include that...you will need to adjust the crop boundary in the view to fix or adjust the view scale so it all fits.
maramuresul
Fit to page is not on scale. I want to be able to print on A3, A4  and so on with  any printer also print to PDF and have something similar like in AutoCAD are the vieports. it should be something that is included in Title Block. Maybe Annotation crop should be included in Title Block .
All the best.
Revit_Whisperer
Revit doesn't work like that...the scale of the view is set by the properties of each view placed on the sheet.  The crop region, when adjusted, determines the extent of the view to show the elements in the view that you want to see.  If the region is not cropped it will encompass the extents of the visible elements.  The annotation crop is for annotative items only and cannot go inside the crop region...it will always be outside of it.
You can print to any paper size you have setup in the printer.  If you want the views to be scaled properly you need to have a corresponding titleblock that is the size you want to print to.  Fit to Page is, as you mentioned, not to scale...it will adjust everything in the view to fit on the size selected in the Print Settings Setup.
