title block set up
title block set up
title block set up
I am setting up the title block for our company and do not understand why the "Project Address" label cannot be edited in sheet view in the same way as the "Project Name" label. They both appear to be the same with just the text size being different.
ennujozlagam
hi, can you post it, if you dont mind so we can check what's wrong with your titleblock. thanks
Thanks a lot
Please see attached.
ennujozlagam
Hi Jon, sorry i cannot open your file i have only Revit 2014 and Revit 2015. Your file is in Revit 2016. Maybe someone can help you. Thanks
L.Maas
I think that it just has to do with that it is mulitline text. Only in recent versions mulitline text has been added as a parameter. Also then a separate entry window is opened when modifying values.
Directly editing of such multiline text on a sheet is not implemented (yet) in Revit. So you will have to go to project information to change those values.
You could consider to submit your question to autodesk and ask if it ican be implemented in a future version.
Louis
Please mention Revit version, especially when uploading Revit files.
thank you
